Hiya,
My SZ3 screen has got remarkably grubby the last few days; with fingerprints all over it.
What is the safest and best way to clean it? I don't want to damage any special coating that may be on it!
Thanks!
Little bit of water ie run your hand under tap then flick sprinkles of water onto your screen.
Then use a cloth (the type you get with a pear of glasses) to clean the screen. Keep cleaning the screen till all the smears have gone!
Best 30 seconds you will spend!
Hi Lydecker,
I use nothing more than a dry microfibre cloth to clean my screen and occasionally I might breathe on the screen to remove some spots. These are available from most shops now.
You may also find this info on Care tips for laptop screens of interest...
thanks guys!
You're welcome..
