Please, I am newbie.
Hi to everyone.
Can I eliminate, and recovery free space on hard disk, the hidden partition on my VGN-FS315M ?
Thank you very much and scuse me for my english language.
Hi, well i had this problem too...
You can eliminate it, when you re-install de OS. For example, i re-installed the Windows XP Pro. and during the installation you come to the partitions menu, where you can see all the partitions. Now you can delete all and create a new partition to install the OS or you can delete the hidded partition.
If you have any questions, don't hecitate to ask.
Saludos
may be a bit of a simple question, but if i follow the instructions on sonys website, will it format the whole drive, and hence lose all progs/data?
Tom
Hi to everyone.
hi, without re-install SO you can do that using a program as PARTITION MAGIC with this great program you can delete/create partitions, resize partition ecc.
on my new FE11M i have do this:
- deleted recovery partition
- reduced C space to 25gb
- increased D space to 70gb
All without lost any kind of files.
naturally i did this after created recovery disks
bye:smileyhappy:
Ok!
I thought about it, but am always a bit wary of using third party partition manager, but if you say it'll work...............
thanks, tom
Backup vital data
too right...........
just finished recovering my C drive, still runs much faster now
very good advice
Tom
Hi Tom,
Did you remove the hidden partition or just complete a system recovery?
