I have re-formated my laptop and put XP Pro on instead, but it seems I dont have Bluetooth installed. How do I install bluetooth on my laptop
Do you have inbuilt bluetooth? If so the drivers will be on VAIO-Link somewhere. Otherwise a USB Bluetooth dongle is only about £25 off ebay :smileygrin:
Install SP2 and you'll not need more software or drivers
No, 3Com probably have an updated driver on their website.
I have just reformated my VGN-A215M laptop, installed XP Pro and downloaded and installed SP2. The problem is after installing on the drivers and getting it working pefect. I have no BLUETOOTH driver installed, can somebody please post a link to the correct Bluetooth driver I need to download, and also tell me if I also need "Bluespace NE" installed also to work with the driver.
I need some help here guys, I have done a clean installation of Windows XP and installed SP2. But I see nothing in the control panel that has anything to do with bluetooth after installing SP2
I'm using a VGN A215M Vaio laptop. Can somebody please tell me what I need to do to get the bluetooth working and if I need to download anything from here like a driver etc. If I do please post a link ti the correct file or files in question I need.
Thanks
check here for the specs of the laptop, there is no bluetooth on this computer for as far as I can s...
So if you purcase, like suggested, a dongle or PCMCIA card this should be autodetected
Well it did come woth bluetooth software installed as factory default, so I'm not sure. I was under the impression it came with it.
So if my laptop does not have bluetooth, why does it come with the software installed as factory default.
Doesn't seem logical does it?
