No matter what I try I cannot get CD info to work, the CDDB registers but fails with socket open failed. Is it because BT Yahoo is my broadband default browser? If so how can I change this. I've had the pocket for several days and am not willing to put music on until I can add the CD info, it's the reason I bought the damn thing. Can anyone help this vaio pocket virgin?:smileysad:
Do you have any firewall software on your PC?
It may be worth turning it off and trying cddb
Also what version of Windows are your running?
Automan.
Yes I have a firewall. Operating system is Windows XP professional. Thanks
