I havent changed the discs or anything, was even writing the same songs as Id already done previously. Is there something I can buy to clean the lens? Im sorry - I just dont know anything about computers really!
Lens ?... Do you mean Discs...
Try this software... is very usefull...
http://www.nero.com/en/index.html
But, i believe... you must have something at your computer to do that...
Hi Bunnygirl
A lens cleaner is usually a normal compact disc with a couple of cleaning heads on them which you dab with a cleaning agent (usually included in the kit) and insert into the drive. You can get them from most PC shops but some stationers or music shops probably stock them as well.
If you have a laptop you can clean the lens using a clean lint free cloth moistened with a little warm water.
Try Nero registry cleaner too, follow itbroker's link for that
