Hi everyone!
Just after a bit of advice really. I'm looking for a hi-cap battery that will be compatible with my AR51M, does anyone know of one or know the part number of one? Would prefer a 7200mAh if pos.
Thanks for your help!
Hi jaylfc1980,
as far as I am aware the batteries used in the AR51M are -
Standard capacity - VGP-BPS2C
Larger capacity - VGP-BPL2C
When searching be aware than some retailers sell non Sony compatible batteries with the same battery model number..
Hi jaylfc1980,
You're welcome jaylfc1980..
