i just had to recover my pc!
and i need som of the software back!
can any one tell me where that i can get, Giga Pocket and Click to DVD from?
its really importent thanks for ur help
paul
Is that not on the recovery DVD?
Should be
Thanks People for ur back up and runing!
I dont no what happend! i restarted my computer last night around 3am UK time becasue the computer was slowing down for som reason. so i restarted the PC.
any way when i restarted it siad it couldnt find winndows i think it was a virus.
I couldnt find why!
so thanks for ur help. and yeah it was on the disc.
thanks people.
Im so glad to be a VAIO member. because the serivce is brillent help! thanks to the VAIO owners (members)
It couldn't find Windows?
Did you get any message?
Have you tried to start in the safe mode?
i had none of that!
all it came up in was SONY then Pentium 4 HT logo then couldnt find windows
Sounds that the Boot sector is destroyed. What you need is a Windows start CD or Floppy disk. If you have nothing of them, then is the only possibility a system recovery.:smileysad:
Yep it is the only way.
Glad to hear you are back up and running now VAIO-Fan, remember to back up your computer regularly, keep your virus scanner up-to-date, scan for spyware and stay on your guard.
Very often these viruses can defeat the anti-tamper locks used by anti-virus software so the virus can then shut down the anti-virus programs in RAM. It has happened to me!
Don't become a statistic!
Two of my friends have had this problem.
The first had to boot into linux and replaced his boot and kernel files.
The second had to return the hard drive to the manufacturer as the boot sector was corrupt beyond repair.
Quite often problems like this are caused by improperly switching of your PC as the laser slams against the side of the hard drive and the boot sectors become damaged.
