Hi.If I have the charger plugged into the laptop is better to remove the battery?
Hi Lailuska,
Depending on which model you have you may find that Vaio Control Centre has a battery care function that will allow you to stop battery charging before it reaches 100% - I believe the default is 80%.
With this enabled there is no need to remove the battery when using mainly on AC power.
Rich
