Help i have just had my netgear router delivered from virgin media and after following the instructions to the letter my computer will not recognise/find the network connection. How do i turn on the wireless on my computer and if any one can help with wireless generally i would really appreciate it
I now feel a bit of an idiot, cause when you asked what model I had, I looked to the back of my desktop and on the side is the switch to turn on the LAN wireless network. DOH
Thanks for your help anyway. All up and running now
:smileyblush:
Glad you've solved your problem..
