I live a long way from a Sony service centre and my wifes VIAO VPCL14S1E indicates that one of the fans is not working properly.
Is there any way one can open the case to check the fan, to clean it...?
Many thanks
Sieg
Hi Sieg
If nobody here can help with first-hand experience, I'm sure Google will find you a workshop manual that you can download.
