Hello!I wonder if anyone has this vaio 3d panel...I cant get it to work with power dvd,cause i cant find it in power dvd s 3d display options.Does anyone know what i should do?I have a european vaio s series laptop model 2011.
Same here. I did found powerdvd on the DVD: if you unzip the 200 MB executable with 7zip, you'll find PowerDVD (9) in one of the folders. However, when I try to install it, I get an error: "Invalid installation for Sony-PC". The default installer hides this error...
Not a clue what it means or how to solve it...
Thanks for the reply my friend!But what is this dvd you found power dvd 9 on?you mean the installation cd for the vaio 3d panel?
Message was edited by: tsomos
Hi tsomos,
could you let us know what model Vaio you have please.?
Also are you still using the pre-installed operating system & applications.?
Hallo!My model number is vpcse1e1e/s.............Yes i use the pre-installed operating system and apps.I did what atlaste said above and i got the same error.Seems like this version of pdvd 9 is not applicable in european models!Does sony know that?I ve seen it world wide in sony sites except the european one.
Problem still remains!Sony must do something!We paid money for this panel and its buggie software.
