hi there im new here and hoping someone can help
I recently purchased this computer second hand from ebay its a sony vaio VGN AR41L. It didnt come with any disks or any other items.
Recently it had a major crash and windows vista got corrupted. So i did a fresh install with windows 7
The problem i am having is that i now cannot find ANY of the drivers for the machine, I cant find drivers for anything, The biggest concern being that i cant find drivers for the dvd rw drive :S and i cant find drivers for the nvida graphics card.
Basically i need the drivers for everything,
thank you kindly for your help
love
angela
Hi Angela and welcome.
You will find all the available downloads for your model on the support website here: -
http://www.sony.co.uk/support/en/product/VGN-AR41L/updates
This model was released with Windows Vista installed and only this OS is fully supported. Windows 7 is not fully supported but most Vista drivers should be compatible with Windows 7.
You may have to search for some Windows 7 drivers.
hi there
thanks for the reply.
If i revert back to vista. wil i be able to get the drivers to get my dvd rw drive working again? also can i get the nvida driver again?
