This is my first post, so forgive me if my netiquette falls short. Suddenly the display on my TZ21 has changed. Previously carefully-arranged icons suddenly re-distributed themsleves all over my desktop and no longer fit as they had before, even with 'align to grid' turned off. The display is still set to the highest resolution and Classic (smallest) icons. Two weeks after this disruption, and shortly after logging onto a hotspot network, a "Vaio Smart Network" window appeared in the bottom right of the screen saying "Switch to 'susan vaio lan' profile successfully." When I click on the Smart Network icon on the task bar, and click 'Exit' I receive an error message that says "Please close all child windows before you exit the application." The problem is, that if the "Switch to 'susan vaio lan' profile successfully" is a child window, I can't close it because there is no visible was to 'X' out of it. These may be two separate problems, but I suspect that the display problem is what's making it impossible to see the way to close the Smart Network child window. I hope someone more experienced than I can help me. Thanks.
Hi scourtneyuk and welcome.
Have you installed all the Vaio Updates - there is an update for the Vaio Smart Network here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-TZ&m=3669
Not sure about the desktop icons but have a look at this link on the Dell forums: -
http://en.community.dell.com/forums/t/19247306.aspx
