halo. I have Vaio PCG-FR315M. I have problem with burning CD R/RW. first, I try it with the window Xp software, bit it Doesn't work.then I try using Nero 5.0 and it does'nt help as well...
what's wrong with my notebook...Does it support burning CD's ( in the technical data stated DVD plus minus RW) what should I do :smileyconfused:: :smileyblush:
What error message are you getting?
test unchecking
