i have upgraded to windows ultimate lovely system but i would like to add application from the applications disc but it will not load in vista even if i use th
e combatability system it will still not load can any one help.
Hi kevinpbetts,
You are not able to install the Sony supplied application from the application disc as you no longer have the original Sony supplied Vista OS and therefore the Vaio recovery centre...
