Hello everyone
I am experencing a big problem with my W1/G Desktop system. Some keys on the right hand side of the keyboard wont work, i even reinstalled the operating system and still with no luck
i have done everything but still with no luck, I connected a USB keyboard to the system and all keys work perfectly but still no luck with my Vaio keyboard
If someone could help me to resolve this issue asap I would be ever so thankful
even if this results in me opening the keyboard, the only thing is that i didnt want to open it as of yet until i have seen your suggestions on this issue.
Thanks in advanced
Deen.L
Letters Not Functioning Are:
9 , 0 , - , P , O , L , I , ; ,
Hi Deen1990,
Which keys are not functioning? There is little to be achieved by disassembling the keyboard btw…
The keys which are not working are.....
9 0 - P O L i ;
Sorry I should have noted that from your original post.
These keys have dual functionality with the numeric keypad – do you by any chance have the NumLk key (function) turned on?
