Any help would be much appreciated.
I've just bought a PCV-V1G. When I tried to run Giga Pocket for the first time is crashed and I had to reset my PC. Upon restart it brought up the new hardware found box and said it had found a new 'Multimedia Video Controller' but it can't find the drivers even when the recovery CD is in. I then tried to run Giga Pocket again, it brings up the following fault: 'FAILIINPUTINFO::Get Available base channel () Function.(0X80004005).
Also when I look at device manager I can't see the TV card anywhere.
Thanks in advance!!
Uninstall gigapocket and restart Windows
Try and get Windows to re-detect the card and install it
Then put gigapocket back on.
