Hi guys,
I'm a new vaio user, from Italy.
I did not find inside the package any disk (we call it in italian "disco di ripristino"), to ristart the system. If I'd like to format my pc, how can I do that?
Many thanks.
Kisses
Angelica :smileygrin:
Hi Angelica and welcome.
It is necessary to create your own recovery disks. There is a hidden partition on the hard drive that contains all the operating system and applications information.
To create the recovery disks click Start, All Programs, VAIO Recovery Tools, and then click VAIO Recovery CD Wizard.
You can also access the recovery utility by pressing F10 repeatedly when you turn on the computer.
Hi Rich,
many thanks for your suggestions.
lots of kisses
Angelica
You can only use +R or -R, no RW
