Hi guyz,
I bought a new sony Vaio VGN-FS415M that come with Windows XP Home so i remove that Win XP Home, i installed Windows XP Pro but now i face a small problem that the speakers dont work at all
i have installed audio drivers from sony website but this doesnt work - i dont know what to do :S
btw - i can hear the the sound when switch on the laptop.
bump - any1?
control panel > Sounds and Audio Devices Properties > i cant select any options - everything is just light fade!!
How can i get the audio drivers work with Windows XP i really wanna listen to the music....
Hi again,
SInce nobody help me so i thought i'd help for others who have the same laptop as mine or silimar model.
just follow these step:
Problems:
PCI Driver - not found (Audio + Modem)
Solution:
if you have already installed Audio Drivers, please Remove it !
download this file from:
Look for KB888111 Driver
Install it - this will pickup Audio and Modem
Good luck
you indeed helped me:smileyapplause:
thank you so much:smileyhappy:
Hi again,
Problems:
Solution:
Good luck
I'm glad your laptop is working now :smileygrin:
Amakia.com - PC Gadgets At Your Fingertips
Goodman :smileygrin: ,
I had this problem on FS 285B, but not anymore
Thanks a lot FiReDuCk
I have the this exact problem due to a recent install of xp pro. However, I have folllowed your advice and cannot find the KB888111 anywhere. perhaps they have changed the content of the page??
I hope you can help.
By the number 888111, it's looking like the HD Audio driver by Microsoft. I'm right?
Well, that's a need to get sound if you have HD audio. Strange that they aren't included at the driver package by Sony.
