i've got a vaio VGN-BX296VP, but i have some questions about the graphics card, it has an intel graphics media accelerator 900 with up to 128 MB max. SHARED with main memory.
but i have only got 10 MB Graphics Memory in use,
how can i change it to 128MB??
can somebody help me plzz??
Thnx
Hi Fouadb and welcome to Club Vaio.
Your Intel 900 chipset shares memory with your RAM.
Allocation of extra memory to the graphics is automatic - when an application needs more graphics memory, the system takes it from free RAM.
If you use graphics intensive applications, you may wish to consider increasing the RAM in your BX - it comes with 512MB but can be upgraded to a maximum of 2048MB.
The BX series is designed for business use primarily and is not really designed for graphics intensive applications.
Thnx meang,,
is there any options to play games with high intensive graphics?????? 😞
128 MB Graphics is not bad - you should be able to play many games but the more modern ones will have to be run with modest graphics settings.
