I get this message on my vaio VGN-CR21Z after installing the OS windows 7 beta. This message does not appear when i disconnet the battery, and the computer is connected to the power grid.
"THE INSTALLED BATTERY MAY NOT BE PROBERLY CONNECTED TO THE COMPUTER OR MAY NOT BE COMPATIBLE WITH THE COMPUTER.
CLICK OK TO ENTER HIBERNATE MODE, AND REMOVE AND REINSERT THE BATTERY.
SEE THE ELECTRONIC VAIO(R) USER GUIDE FOR MORE INFORMATION ABOUT USING THE BATTERY"
I am totally clueless about what to do, so please help me - anyone....
Hi Quetzcoatl,
welcome to Club VAIO..
Have you installed the Battery Checker Utility.?
If not you can download the original utilities and drivers for your Vaio using the following link: CR21Z Original Utilities & Drivers Packages
Thank you Thalamus.
Yes - the battery checker utility is installed. I've downloaded and installed the original drivers and utilitys from excactly the same link you posted. The problem still remains....
Any other ideas on how to solve the problem?!?!?
