Does anyone know if the Vaio VGN AR21M can play HD DVDs? It says on the sticker on the laptop "Full HD 1080" don't know what it means though
Only BD from what I understand
I know the AR21S plays Blu-Ray discs but the AR21M doesn't... can AR21M play HD DVDs though or do you need a new disc drive?
HD-DVD and Blu-Ray are different formats of HD disc.
At the moment NO drive can play both types of disc. A player is being developed that will handle both but I think it will be a long time before a notebook drive can do this.
The purpose of these formats is the same and in the longer term one will be the winner and the other will possibly disappear - you are probably too young to remember the VHS vs Beta-Max video war when a lot of people wasted their money on the Beta-Max (Sony) system.
This time Sony and Dell are adopting Blu-Ray and Toshiba HS-DVD. Personally, I don't intend to buy either until the format has some real use to the ordinary user.
To answer your original question - No, the AR21M has a normal DVD/CD-ROM drive and you have to pay £800 more for the Blu-Ray equipped AR21S.
Full HD 1080 refers to the maximum resolution supported by the HDMI output on the AR21M - but I find this misleading as you do not have an optical drive that can import HD/BD content, or for that matter a screen that can display 1080i/p
Good point Baggsy.
And the information regarding the adult film industry was very 'revealing' :smileygrin:
Good point Baggsy.
There's going to be a new format called HD Freedom, which is just a blu ray layer on top of a HD DVD so it can play in both. God knows how many film companies will go for this?
Hopefully the nudey ones :smileygrin:
