Just got my shiny new T2XP which is great! Tried to use the bluetooth headset from my phone(HBH-65), which works fine with my old tosh. The device has been discovered OK and added fine, but with no services. Can you tell me what I should do to get these two sony products to work together.
Thanks,
Ian
The bluetooth on the VAIO is using the Microsoft bluetooth stack. The headset profile is not supported (unfortunately this is the same on all VAIOs with BT). Unless you can get the Bluetooth stack elsewhere or buy a USB/BT dongle with it's own software, you won't be able to use the headset with the built-in BT of the VAIO. This has been the case for a few VAIO models already.
We can only hope future models will use different software to manage the Bluetooth functionality
Thanks for the info, I didn't know this
