Going to upgrade my harddrive in my pcg-k215s to a 7200rpm.I think this is why its quite slow compared to my desktop computer, Which is only 2ghz. What is the max size i can put in due to bios limits, or is there none.
P.s Anybody Heard anything a driver update for the ati mobility 9200 graphics card.Still having problems with games,ect
An 80GB disk should work
Driverupdates for ATI graficscard?
http://www.ati.com/
But better you look on the Sony support Side
http://www.vaio-link.com/index/index.asp?l=en
You cant get drivers from ATi for your card, you will have to get them from sony. You could try the Omega Drivers, just search on google. But remember, laptop systems are not designed for playing games, dont expect killer performance just because your laptop is new.
