Hello everyone,
i have a FS195XP and it has a C drive and D drive for hard disks.
But it only uses the 10GB C drive. How do i change it so it uses the D drive.
thanks in advance
You can use the Recovery Disk and get a New Partition.
Ok, ill try that. thanks a lot.
Can you clarify whether you are wanting an additional partition or just looking to store files on the D drive:smileyconfused:
Yep need more info
Maybe he want install Windows on drive 😧 ? But for this, he need a Windows CD.
And where is the problem?
the C drive keeps filling up and it says it will only run well with 200MB left so i have to keep on deleting files.
Just move all your files to 😧
