I'd like to get some more internal memory for my A317S. Does anyone know if this is possible?
If not, can I move memory from my D drive to my C drive, and how do I do it!
Thanks in advance
Peter:smileyconfused:
Hi Peter.
Do you mean?
Physical memory (RAM)
Vitual Memory
Partition size (C & D drive)
Or as the title says a replacement larger HDD
Its probably just me but I am confused
William
Thanks for your reply. I mean Hard Disk Drive. I have 100gb at present but need more internal memory. If it is not possible to upgrade, I then need to move some from partitions.
You can upgrade your hard drive but notebook drives dont get much larger than 100gb, i have a 120gb in my A517S. Prehaps an external drive would be more logical:smileyconfused:
Thanks. Can you tell me how to move some memory between partitions. I have not much on C (which has program files, my docs, my music etc) and lots on D.
You could use Partition Magic, but I'd backup before using it as it can make errors
