Can anyone inform me of the maximum capacities for me to upgrade HD and memory for my laptop VAIO VGN-FS 315S?
Hi Mohammud,
Maximum supported memory is 2GB (1GB per slot).
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-FS315S&Cat=RAM
The original dive is 100GB and as far as I am aware there is no BIOS limit on size. A 320GB hard drive should be fine – you need a 2.5” x 8.5mm IDE drive.
Rich
Hi Mohammud,
Rich
Thank you for your helpful response.
You’re welcome:smileyhappy:
