Hard disk space on T1xp
mikekennedy1
Visitor
I have now owned my T1XP for a couple of months and it is the best notebook I've had. I do however have a problem and am stumped on how best to solve it. I have some knowledge of computers but am not an expert.
The notebook' hard disk is partitioned (i think) as follows;
C drive - space 13.9gb - has 2.2gb free
D drive - space 16.2 gb - has 13.9 gb spare
I have already had a warning appear that I am low on space. I have tried where possible to load anything new to D. I synchronise with a desktop - making use of the 'offline files' facility (total size approx 2gb) but these are by default stored on C.
I would welcome any help on this. My thought was to maybe amend the size of C i.e. increase it by reducing D - or to as a minimum try and have the offline files stored on D.
Help!!
3 REPLIES 3
profile.country.GB.title
rich912
Contributor
Hi Mike and welcome to the forum.
Maybe the easiest solution would be to move your 'My Documents' folder over to the D drive.
In explorer right click My Documents and select Properties, click on move and select the D drive.
This should free up some space on the C drive.
Go n-éirí an bóthar leat
mikekennedy1
Visitor
Thanks Rich
The size of the My Docs folder is only 72MB - so although it would make an improvement - it doesn't solve it!
rich912
Contributor
In that case you can use Parition Magic to re-size your partitions, but backup everything first as sh*t happens!
Partition Magic
