Hi, I've got a problem with my Hard Disk - it has a damage and now I need a new one. My old one had 20GB - but now I don't know if the model PCG-FX403 supports also a bigger one with 60GB. How can I find this out?
Thanks.
Chris
Email sony I suppose
There is a 32GB limit but it normally only affects a few computers with the Award BIOS. There is a good chance that your computer will support 60GB but the only way to be sure will be to try it or hope someone else has already tried and posts a follow-up.
Sony don't usually know or won't tell you
Have to agree with Rob, it should be able to accept the 80GB drive.
Shop around, you can get some top deals.
