Just noticed at Vaio village that another unfortunate soul has a problem with their GRX memory slots.
William
Thanks for the kind words guys.
I have decided to soldier on with the one working slot, I guess I should count my blessings that I have 2X512Mb.
Since removing the second stick evyrything has returned to normal albeit with 512Mb rather than my desired 1.0Gb.
I think I was prepared for this by reading earlier posts so it is not a great shock.
I feel let down by Sony due their inability to acknowledge the problem exists extensively.
By looking at the Acer site I have realised that a £1500 laptop is actually higher specced than a £2500 Sony.
My Sony brand allegiance has taken a hammering.
I was going to say sorry Sony but any future laptop purchases will be elsewhere, but hell they owe me an apology.
William
Well for £1000 you can get a lot more from other brands than Sony, sad but true
Edit: cool I fixed the page counter thingy. Now everyone can read William's reply
William, have you tried the 'solution' that was posted on the American site? Apparently, if you put a piece of cardboard between the memory slots and the outside casing (trial & error for correct thickness) the problem should disappear.
A little amateurish I know but losing 512Mb ram really hurts
Hi Dave,
Yes I have but then my initial greed for ram wore off.
The cardboard fix has worked well for some but others have reported that this is only a temporary fix and eventually it won't boot from either socket.
Maybe it is all only temporary but time will tell.
William
The machine is too good to simply bin - how about a professional repair. If you know what the problem is it shouldn't cost too much to sort - should it?
I have PCG GRX550 and i have same boot Problems... Currently removed one RAm and using packing to enable boot... If you have similar problems join [email protected] and post your problems at [email protected]....
Sony does not support motherboard replacement after warrenty as $$ issues....
Sony does not support motherboard replacement after warrenty as $$ issues.... ? send this to as many people as you can....
Wow, it must be something if there's a yahoo group.
How many members?
I think it's about time someone from Sony took their head out of the sand.
A petition has also started:
http://www.petitiononline.com/so...tion.htmlj
Do a search for GRX.
William
