Hi all,
We have a HW-problem on our GRV616S, more precisely it's related to the memory chip / memory bank.
There is a long treath related to this problem on:
http://www.hardwareanalysis.com/content/topic/5449/
Currently the NB is running on 256MB, which is killing us. We are afraid however that buying a new 512MB-chip, without testing-possibility, would not work.
Can any1 share experience on this issue, or point to a place for VAIO-certified memory purchase?
Tnx
I had this problem with my GRX316SP - one slot died - you can use 1 @ 512Mb card in the good slot and it should work fine.
I bought my memory from http://www.crucial.com/eu/index.asp
Tnx for the info Rob :!:
Will share it asap with The Affected One
A quick glance on the Crucial-site learned me that their prices seem reasonable.
Their tech support is good too.
