since some days I have problems with my laptop. When open pictures the fan starts with full power and after some time the computer stucked up. switching off only possible by pulling the battery. After switching on again, working normal until the next picture. Is it possible to repair or change the graphic card and what will be the costs apprx.
what picture you open and with what software you open it?.
Pictures which I made with my digital camera
Software: Irfanview and Nero Photo Snap Viewer
Does the same occur with Windows Explorer or My Computer?
thanks for reply,
same happens with windows explorer or my computer. Also if I choose screensaver slideshow (windows) with my pictures.
hmm seems like kee-lo know whats the problems?
Heh I wish, this is very strange!
I take it you checked for new updates on www.vaio-link.com?
If the fans are going full blast (
) then I would think there is an overheating problem when there is load on the CPU. Try cleaning the dust out of the laptop and see if this helps.
