Recently bought a Vaio -N11S, but the graphics card is not compatible with some of my software. Can you upgrade it in any way?
Any advice appreciated :smileygrin:
Hi MrNibbles,
Welcome to Club Vaio,
Unfortunately it's not possible to upgrade as the graphics chip is soldered to the motherboard..
What software are you having problems with...
Most latest games are incompatible to mobile chipsets. NeedforSpeed Carbon for example. It may work, but not more. So, if you get Bluescreens within playing games, it's most times because of incompatibility or overheating(older VAIO laptops with Desktop CPU) .
