i have a all in one computer with a nvidia 310m graphics card but cannot find a updated driver that works ones on nvidia website dont .
Hi n1ck21,
If there is an updated driver that has been tested and released by Sony you will find it on the support site under your model.
http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
The drivers released by NVIDIA will not install on your Vaio without a modified inf file. If you want to install drivers released by NVIDIA then have a look at the following link – this is of course at your own risk.
http://www.laptopvideo2go.com/drivers
Be sure to read the Quick Start Guide.
Rich
Hi n1ck21,
Rich
