I currently have a 64Mb graphics card. With the work it do, 3d animation I finding it very slow and unable to cope with some tasks especially at 1920x1200.
Can the graphics card be upgraded?
If so can I use the one from the A497XP, a 256 Mb card?
You can't upgrade the graphics card in a laptop.
You can't upgrade the graphics card in a Vaio laptop. They are built into the motherboard. It's the same with all consumer laptops.
3D rendering is best done on a desktop with a PCIE card
