Anyone know where i can find graphics card drivers for my FZ5200? I,v tried the latest
nvidia drivers but the graphics on call of duty were flashing etc. It only seems to work with the sony driver that came with it.
Sorry, I don't actually recognise that model, so not sure what card it has. If it's a desktop and has an nVidia card then the nVidia drivers should work. Of course it may be a bug with the game so it may be worth checking for a game update, or see if it's a known issue with the newest nVidia drivers.
You can also check out www.omegacorner.com for custom drivers and also have a look at www.vaio-link.com and see if they have any updates for the card.
thanks for the info guys.
My mistake, the card is a FX5200 and the system is a PCV RS222.
think ill check for a game update as the new driver works well on everything else.
i just thought that sony had there own driver for there card as it seems to work the best all round even though its an older version.
