Does anyone know how to turn the anti aliasing on this PC. The graphic card seems to be working but I can't find this option anywhere, and the games I've been playing are full of 'jaggies'.
I would try phoning the Sony support line, but they don't seem to have much of a clue.
Thanks in advance,
Andrew
All of the available settings will be in Display properties, Settings, Advanced. Quite often these settings will be overidden by the in game graphics settings.
hi
if that doesn't work try to update the nvidia driver to 45.23. there you can put it on!
at screen properties (where you change res.) then extended and geforce fx 5600 you'll find it
you can also do it in 'system preferences'
Yup, these were greyed out when I got my Vaio. An install of the latest nVidia drivers from their site, not Sonys, will do the job. Just go into display properties, advanced and they should be in there somewhere, although the other poster was right, some games do override it anyway
Sorry,
this ain't an answer to your question, but i need to know cos i want to buy a new video card:
how powerful is your psu?
when you open your pc it is written on the the back of the psu.
whats the name of yur pc?
the video card is a geforce fx 5600 (ultra)
steffen
