My Gigapocket is acting up it crashes the pc and forces a restart how can I re-install it without a complete system restore
Yeah go to "Add or Remove programs" witch you can find on the control panel.
Uninstall:
Giga Pocket 5.5
Giga Pocket Demo Movie
Giga Pocket Hardware Library 5.5
That will remove Giga Pocket completely:smileygrin:
my gigapocket is only ver 5, it comes as part of the restore disks,
I dont want to do a full re-nstall
Insert your Vaio recovery disc: click continure, Click Go on "install individual applications" and choose what program that you wanna reinstall.
But you have to uninstall Gigapocket 5.0 manually before reinstalling.
The system disks for my PC are "restore Disks"
they need to boot the pc from startup, they are not install disks lika a windows CD. they seem to be more like a data dump thing:smileycry:
Its a PCV RZ221
Master,
Which model desktop do you have?
Sorry its been a long day .
Its on disk 4
I was just about to post that your model does not have the Vaio recovery utility, which would explain why nothing happens when you insert the CD and that you should search all disks.
Pleased to hear that you have now found it though:smileyhappy:
Glad it all worked out for you Master.
