Hi! Thanks for your help!
I've just connect my PC VAIO with videorecorder to convert analogic VHS i digital format using GigaPocket.That's fine!
I have just a question: in this matter, what is the difference between giga pocket and DVgate plus? What is the best for my needs?
Thanks for your advices
rox
I would record the movies on DVD (I have to use "Clik to DVD"?). In some cases I would also modify the video (cutting sequences, add title,......)
What do you suggest me?
Thanks
Rox
Thanks
Rox
DVGate allows you to edit the movies, whereas Gigapocket just records.
