I have a FZ11S Vaio which less than 2 years old, I have a issue with display, its resolution has changed to low and Vista has disabled the NVIDA display adaptor saying it is returning error code 43. I could see green lines on my display when I start the machine and it stays even after the Vista loads.
Are you right clicking the background and slecting personalize then display settings to change the resolution?
Also have you got all the latest updates for your laptop? If not go here: http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-FZ&m=2666
Hope this helps, Mark.
Hi vijayanand.is,
welcome to Club VAIO..
Try this..
1. Download the nVidia Driver 7.15.11.128 update using the following link: nVidia Driver 7.15.11.128 update and save it to download directory.
2. Close all running programs.
3. Go to the download directory and double-click the downloaded file.
4. Click "Finish".
5. Go to "Device Manager" (click Start > right-click Computer > click Manage > select Device Manager).
6. Expand "Display Adapters".
7. Right Click "NVIDIA GeForce 8xxx" and select Uninstall.
8. Check "Delete the driver software for this device" and click "OK".
9. Restart the notebook.
10. Repeat steps 5-6 above.
11. Right Click "Standard VGA graphics adapter" and select "Update Driver Software..."
12. Select "Browse my computer for device software".
13. Select "Let me pick from a list of device drivers on my computer".
14. Click "Have Disk..." and then click "Browse...".
15. Select "C:\Update\NVDVID-01193630\nvsz" and click "Open" and then "OK".
16. Click "Next" and wait while the Wizard updates your software.
17. After the installation is completed, click "close" and restart your system.
18. After the system has finished restarting, proceed with the below steps.
19. Right-click the desktop and choose "NVIDIA Control Panel".
20. Select "Video and Television", and click "Adjust video color settings".
21. Click "Restore Defaults" and click "Apply".
22. Select "Apply these setting to all video technologies" and click "Apply".
