The symptoms:
Wenn I hit the power button power light comes on and stays, battery 1 and 2 lights turns on and off then num lock, caps lock, scroll lock lights tuns on and off. HDD light never turns on but spins. I get nothing on the screen , no beeps. I have tried the ram in another laptop also put another one and its good, have reset the bios using the reset button, also left the cmos battery out over night, still nothing, also have tried external monitor.
After disasembling and assembling the laptop it started working for about 1 min and than down again with the same simptoms.It seems to me something in the motherboard, bad connection or heating problem. In 2 days started again for about a min (windows satrted) and than down again.
Any ideas what could be the problem.
BR
Sounds like a power problem to me. Can't be 100% sure.
