Hi
I have an fx401 that still looks to be going strong despite a broken battery. I want to upgrade the memory in it. The official spec says that 512MB is the most you can fit but I have seen 512MB 200pin PC133 SO-DIMMS avaiable which should take it up to 1Gig. Does anyone know if these will work?
Many thanks
Richard
Hi bellamyr,
Welcome to club vaio,
Unfortunately no the maximum RAM is 512MB...
I also think a 256MB module is the maximum your vaio will accept...:smileywink:
Quick response.
Thank very much. I'll spend the extra cash on a bigger disk instead. I also have a CPU I need to drop in.
Thanks again
Richard
You're welcome Richard,
