HI all, i was wondering if anyone could help me..... i recently bought a vaio k415b. i decided to upgrade the operating system to xp professional. after it had installed i managed to install al the correct drivers for all of the hardware but i cannot manage to get the function keys to work.
i have installed the hotkey utility for my specific model but the keys still wont function - the only one that will work is the num lock/ scroll lock key!!
if anybody knows what i am doing wrong or what i need to do, i would much appreciate the help.
cheers
Hi
You need to download utils.exe from www.vaio-link.com - I think they list it as Sony Utilities or maybe it's in the original drivers pack
ive downloaded the utilities pack and installed all the exe files but still wont work...
