Hi All,
Its my first post because I have a problem with my
PCG-GRS515M aka PCG-8E2M.
The keyboard characters UIOPJKL:M will not display their correct character unless I press the Fn key.
Can anyone help?
regds
Phil C
Hi Phil C,
Welcome to Club Vaio,
Do you by chance have number lock turned on...?
Hi ,
Thanks for the reply. Yes you are right . How do i stop NUm Lock automatically on power up?
regds
Phil C
Hi Phil,
You should be able to do this by pressing the Num Lk key (top right of the keyboard) to turn the number lock off and then restart your Vaio..
Thank you very much - i never use the Num lock key. Musy have presssed by mistake.
many thanks -
Phil C
You're welcome Phil C...
