I have a VGN-S4M notebook.
Today I am not able to adjust the volume control by
pressing the Fn Key + F3/F4 respectively
The Fn Key + F5/F6 does not seem to be functioning either.
Have I locked / disabled something or do I have a HW problem?
Thank You
Hi Hansc,
A recent update has corrupted your Sony Utilities.
Try navigating to C:\Utils and double clicking on Utils.exe. This should reinstall your Sony Utilities.
If this does not work, download the original Preinstalled Utilities for your Vaio from VAIO-LINK DOWNLOADS and unpack the compressed files to a temporary folder.
Install the following folders IN ORDER: -
1 Sony Utilities (Installer Folder 1)
2 Sony Shared Library (Installer Folder 2)
3 Vaio Event Service (Installer Folder 7)
and reboot your Vaio.
You may have to do this more than once to get a result.
Hi Blencogo,
Thank you very much for your quick answer .
Seems a bit complicated for me, but I will try.
Would of course appreciate if I may come back
if I dont manage.
Thanks a lot, Hans y
Hi Hans,
Yes, please feel free to come baclk anytime!!!!
One of us will be able to help.
:smileyd_oh:
Hi Hans,
:smileyd_oh:
THANK YOU VERY MUCH FOR YOUR MOST PROFESSIONAL
AND EFFECTIVE RESOLUTION SUGGESTION.
Yes it took a twice to resolve the problem. Something I would
never have been able to work out.
Much appreciated and REAL ADDED VALUE FOR VAIO.
Thanks, Hans
