the volume and brightness controls on my PCG-FR415M do not work. Will using the recovery disc restore them ?
Also on start up I get a message "Windows-disk No disk in drive. Please insert disk "
Any help appreciated. Thanks
[email protected]
[email protected]
Try running C:/Utils.exe and see if that restores them. Failing that you'll have to go for the recovery option.
