I have windows XP (with service pack 2) and I can't switch screen on my TV. I have an error message with the file rundll32.exe.
Help me please.
Thank's
What exactly is the error message you are getting? Can you be a little more specific?
If it stems from RUNDLL32.EXE then Windows Control Panel will not work either... In this case backup everything on your computer and preform a full system recovery from the supplied DVD disk/CD set/recovery partition (if you have this you MUST back this up onto CD or DVD media).
I already perform a system backup and I have the same error message. This message is : the file rundll32.exe has occured an error. And windows propose me if I want send or not the error rapport.
Have you set the TV as the primary display?
