- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
FPS
hy again, have i mor fraps per second whith 256mb ddr or with 512 mb ddr, or counts only the graphic card???
thanks for help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I assume you mean in a game ...... if you do then the graphics card will be the most important but frame rate may increase if system memory is upgraded. Games will normally run smoother with extra system memory.
Regards, Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Graphic cards determin your FPS, though if you have a good FPS, you need good hardware to back up that level of processing, so there isn't a bottleneck. Adding more memory can help the processes work faster, but more often, better GFX cards give better FPS' with an equally good CPU. So for example a P4 3Ghz with a Geforce 4 4600 is going to give better FPS than a P3 800Mhz with a Geforce 4 4600. Another example would be a P3 800Mhz with a Geforce 2 MX would have less performance than a P3 800Mhz with a Geforce 3 MX.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I thought that was what I said
Regards, Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hmm, damn, I wasn't concentrating again, and made a long winded version of your reply.
:smileyblush:
