First of all, I know that there is another thread regarding this topic, but I thought that it would be better to start a new one related to the specific problems I have.
I decided to format my PC and I backed up my SS library. I then transferred the file to my VP. I did the format and everything was great until I had to install SS. So, I installed the software from the cd and then upgraded it to v2.3 (downloaded from club vaio site). After that, I used the backup tool in order to restore my library. Authentication was done and everything seemed great.
I then went to the Connect website (Europe), and my system requirements were checked and it was noted that I had to install the sonicstageinstaller.exe (EU version).
OK, so I did. Now I have two probelms. The first one is that whenever I try to login to Connect, I get a meassage saying "Sorry, your user account is not valid for this software license and this computer. "
The second problem is that whenever I try to play a song with SS, I get a message saying that I have to connect to internet to obtain a license, but when I do that I get the following message:
"There is invalid rights management information in the OpenMG content"
Now I understand why everyone is complaining about SS. Why does it have to be difficult? I hope there is a solution to my problems (except ripping all mt cds again)
Please help me!!!!
Thanks in advance
Write a E-Mail to the Connect-Team. They can help you.
After this I would stop using connect. Its way too expensive and the website is rubbish, difficult to get what you want and there database is a bit difficult to interpate.
allofmp3 is meant to be good, if your russians any good:smileygrin:
Allofmp3 is even better when you press the button saying 'English' at the top of the page
though I haven't used it
Don't forget that you can chose the file quality.
But : higher Bitrate = higher price
Allofmp3 is even better when you press the button saying 'English' at the top of the pagethough I haven't used it
