Hello
My Fn (Function) key has just stopped working. I can no longer use it in combination with mute, increase or decrease volume, increase or decrease brightness etc.
I would be grateful for any ideas on how to restore it to operation.
irritated
Reinstall the utilities with C:\utils\utilities.exe
Or download the Utility package from VAIO-Link and install the Hotkeys.
Or just check whether HKserv in systemstart is enable
(start > run > msconfig > systemstart)
Hope this helps.
Happy New Year.
